Rear brakes squeak? Take a look...
Old Sep 18, 2010 | 09:08 AM
opdsgt's Avatar
So far, these Wagners are dead quiet. Maybe they're onto something with the thickly coated, integrated shims on the back side of the pads. I'm pleased.
Old Sep 18, 2010 | 12:12 PM
Mike Davis's Avatar
Default Rear pads
OK so I only use my 08 X as a DD. After all the buzz on rear pads wearing down at 20, 25 and 30k I thought I'd better check them b4 winter. I have 23.5k and the pads are just about as thick as the pad metal base plate, about .25 in. If they were .5 or .6 thick when new then they are about half worn.
Old Sep 19, 2010 | 06:00 PM
kirstcc's Avatar
Default Squeek...squeek...squeek
I have 17k miles and have had the squeek when I just lightly press the pedal. Sounds like right rear. I've only stuck my head under and it looks like I have plenty of pad left.
I was afraid I bent something cause it goes" squeek..squeek...squeek...squeek".
Does that mean I should just swap out my pads?
Old Sep 19, 2010 | 06:23 PM
opdsgt's Avatar
I would at least pull the caliper and remove the pads to inspect... check for disintegrating shims like I observed on my factory pads.
Old Sep 19, 2010 | 06:31 PM
Yamaha90's Avatar
yup, i was there too at 35K
no more brake pad left on any rear. Squealer clip had broke off after only a day.
Old Sep 20, 2010 | 04:58 AM
thissideup's Avatar
I had a squeak squeak squeak as well. was there even after I put on my new pads Turnrd out with a little exploring thta my axle shaft was bent. I positioned my mirror to watch the edge of my tire....wow it wiggled????? pulled everything apart and found the shaft had an 1/8-1/4 inch of a twist in the splines....
Old Sep 20, 2010 | 05:14 AM
opdsgt's Avatar
Eek.
Well, if my squeak comes back, I'll pull the wheel, spacer and rotor and put a dial indicator on the flange to see how much runout I've got. A tweaked flange can result in a squeak like this too.
Old Sep 20, 2010 | 11:29 AM
Biggy's Avatar
Same thing here. I just ordered new shafts from Northridge.
