Recovery question
Old Feb 1, 2010 | 07:47 PM
SWRUBI's Avatar
Default Recovery question
When I bought my 08 it didn't have a tow hook in the rear like the 09-10's do. I purchased a D ring that plops into the tow receiver in back. If I need to be recovered or recover another rig using this method -- how safe is it? I read the tow rating at 1000-2000 pounds so no I'm wondering if I wouldn't do damage in the back by using this set-up if needed?
Old Feb 1, 2010 | 07:49 PM
GoodysGotaCuda's Avatar
It's plenty save. The factory tow hook in applications without the tow package is mounted in the exact fashion as the stock tow receiver. I personally just have slipped my loop end into the receiver and used the hitch pin to retain it for recovery. Either works.
Old Feb 2, 2010 | 02:45 AM
Mark Doiron's Avatar
Originally Posted by RRCP08JK
... I'm wondering if I wouldn't do damage in the back by using this set-up if needed?
Nope, use it all the time. Here I am rescuing my former pastor's Jeep after he landed axles-deep in a ditch during our Christmas Eve blizzard ...
Old Feb 2, 2010 | 03:05 AM
HappyCurmudgeon's Avatar
Eternal ***erator
I have the PJ rear swingaway. I put the extra tow points on it and i still carry my receiver D-ring. Depending on the angle and what i am doing i would use any one or combination of the three points to get a straight pull. I wont & havent hesitated to use the receiver one. I have used it for everything from hauling people out of the ditch to playing lumberjack and pulling over/holding trees to be cut. One of the best small investments i made for the Jeep.
Old Feb 2, 2010 | 04:34 AM
abundigas's Avatar
The hitch might be even stronger than the factory tow hook, it has more contact points with the frame, and I think will distrubute the load evenly to both sides of the frame.
Old Feb 2, 2010 | 04:47 AM
drschem's Avatar
Just remember that getting stuck and subsequent recovery always brings a risk of damage to your vehical or bystanders. Always survey the situation with a "What would happen if..." mindframe and put in various scenerios to make a plan that minimize bad events from happening.
Old Feb 2, 2010 | 07:07 AM
jackson2010jk's Avatar
Correct me if I am wrong, but I heard using the hitch pin is not a good idea as the forces will cause the pin to shear and cause a lash back of your recovery gear?
I have never used it, so I am in no way knocking on you for using this method, I have just been told not to.
As far as the OP, using a center d ring on the hitch is fine, And a great idea to keep a cleaner look without getting a new bumper.
Old Feb 2, 2010 | 07:53 AM
Bennyhana's Avatar
The force on the pin is not that much different when using the d-ring slug vs, just the pin. The leverage on the pin is different and with the pin only I say you are more likely to bend it and have a problem getting it out.
Old Feb 2, 2010 | 07:58 AM
Vernnz's Avatar
I read the tow rating at 1000-2000 pounds so now I'm wondering if I wouldn't do damage in the back by using this set-up if needed?
The tow rating is based on vehicle parameters like weight, brakes, wheel base, etc. The tow rating is the amount of mass that the Jeep can control at normal driving speeds.
The factory hitch connects directly to a main cross member of the frame. This is more than adequate for recovery operations.
Old Feb 2, 2010 | 08:25 AM
Thanks for that, I knew it wasnt a huge risk, but I read that is was "frowned upon"
And I could see you bending it and having troubles removing afterwards.
