reduce power steering boost?
Hey guys-
Is there some kind of shim change or something that can reduce the power steering boost on my JK?
I know on these old-style PS pumps some can be modified with shims to reduce the pressure and reduce boost. Anyone tried this?
Thx-
Thx-
Maybe an underdrive pully for the pump?
That wouldn't help, for the obvious reason that even at idle the power steering is at full boost. It has a relief valve, it equalizes pressure.
The way to fix it is by adjusting that valve so that it doesn't allow as high pressure at all times.
Here's an example of an article that talks about modifying the pump to tune the right pressure:
Modifying your Power Steering Pump - GM Truck Central
It's apparently common with hot rods etc. to have to modify the pump for the appropriate application.
But 95% of the time or more this Jeep will be on pavement. I'd prefer more steering feel.
