Removing the carpet??
Does anything need to be removed prior to removing the carpet like trim pieces etc? And is it hard to put it back in and keep everything looking factory? Thanks in advance
If you have a sub, it will have to be removed. You will also have to cut two places about 1" long under the two front seats. You can see where it was cut at the factory but no all the way. There are also some little plastic nuts under the front seats and up next to the fire wall. It takes about 15-20min. It goes back in easy as well. I had to remove my wife's after our 4yo spilled a pint of chocolate milk in the floor.
