Removing a fender
What are some basics I got to know about removing fender panels from the jeep? Is it pretty easy? just remove the bolts and clips? and it's off? Do I have to worry about any adhesives from the factory that might be used to attached the fender to the body?
Thanks
Thanks
Removing the fender flares is not very hard, but there are steps need to be done.
For the front fenders, there are hardwares that support the fenders, after you remove the fenders, you may also need to remove the hardwares under the front fenders. For the rear fenders, I think is little easier than the front ones.
Thanks for the help guys
that should be easy for the flares what about the actual fender? Someone gave me these full steel ones that is one piece with the flare. I'm assuming the fender itself is attached with bolts.
