Removing front seats and what not to do.
I'm going to spray my interior with raptor liner. I'm done all the prep in the back of the jeep but have left both front seats in because i'm concerned of throwing a code and not being able to start the jeep which I read can happen. So i know you should disconnect the battery before disconnecting the connecters under the seat. Can I reconnect the battery and move the jeep while the seats are out of the front. I want to be able to move the jeep in and out of the garage during the process of the mod.
When you do disconnect any connections just be careful with the plastic clips as they tend to break very easily if you pry to hard to get them apart. If you have to disconnect any yellow connections be aware that these are airbag connections and yes the battery should be disconnected although the possibility of setting one off is remote. Once you have all your wires wrapped up and out of the way, bed lining the rest of the jeep should be a breeze!! You should be able to drive it in and out with no issues without a seat?
2cents
Agree with you here and as for driving it, I have driven other vehicles with front seats removed and electrical disconnected, not sure why Jeeps would be different. If you have too, put it in N and PUSH!!
Let us know if the Jeep explodes - I'm digging in just in case
as far as your airbag going off, its very unlikely. airbags arent like grenades, they dont blow up if you drop them. they are set off by sensors in the car when a movement is abrupt enough. or a sudden change in direction (getting Tboned).
