Replace Rear Wheel Speed Sensor Question
I have a 2012 Rubicon and recently had it throw a code that rear wheel speed sensor was bad. Went underneath and found sensor and the connector, got the red lock loose on the connector by pulling it out. Now I am trying to pull off the connector from the sensor and it won't come off, it feels like there is something else that is still locking it in. Does this connector pull straight off or is there another lock/tab/whatever still holding it on? I have to get the connector off first in order for the sensor to come out and clear the axle, etc.
The red lock slides out-all the way out- then you've got to push the black flap down for it to release. If the red tab isn't all the way out then it won't let you unhook from the sensor.
Rotate the sensor when you pull it from the back of the wheel, it comes out nicer that way.
