Replacing ABS Module 2013 JKU
My 2013 JKU has ABS light and Traction control light on for some time
Codes show
C2206 - Vehicle Configuration MisMatch
C1073 - ABS Pump Contrl Circuit
C121C - torque request signal denied
sounds like I need a new ABS module??
has anyone replaced this? Is a scanner really necessary to bleed the breaks as the service manual indicates? Any chance of replaceing the control module without replacing the junction block (thus maybe eliminatating the need to bleed brakes?)
Thanks!
Codes show
Thanks!
I'd imagine you could get Chrysler to repair this under your 5yr drivetrain? Even if your warranty wouldn't I would imagine they would because of the safety concern.. I have had luck getting extended warranties for free and things covered by giving them a hard time when parts fail prematurely.
