Replacing all Lubes
Old Apr 9, 2008 | 05:17 PM
JackMac4's Avatar
Originally Posted by ronjenx
Automatic Transmission Mopart ATF+4 Automatic Transmission Fluid
Manual Transmission Mopart Manual Transmission Lubricant or equivalent (meeting the requirements
of DaimlerChrysler Material Standard MS-9224)Make SURE you use the correct API GL rated oil in the manual transmission. I once used the wrong number and the synchros went straight to hell. The synchros need the correct additives, as defined by the API GL number.
Transfer Case Mopart ATF+4 Automatic Transmission Fluid or equivalent.
Axle Differential (Front) Mopart Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent.
Axle Differential (Rear) 198 RBI (Model 35) and 226 RBI (Model 44) - Mopart Gear & Axle Lubricant
(SAE 80W-90) (API GL-5) or equivalent. For trailer towing, use Mopart
Synthetic Gear & Axle Lubricant (SAE 75W-140) or equivalent. Models
equipped with Trac-Lok require an additive.
Brake Master Cylinder Mopart DOT 3 Brake Fluid, SAE J1703 should be used. If DOT 3, SAE J1703
brake fluid is not available, then DOT 4 is acceptable. Use only recommended
brake fluids.
Power Steering Reservoir Mopart ATF+4 Automatic Transmission Fluid
I thought it was 75W90 for the front and rear diff....
Old Apr 21, 2008 | 10:34 AM
silver rube jk's Avatar
I used 75-140 AMSOil in the diffs. AMSOil MTF 5-30 in the tranny and AMSOil ATF in the transfer case and the whole drive train is much smoother and i picked up about 1.5 mpg. As a side note, the folks at chrysler must have given zero though about putting the manual tranny drain plug an inch above the exhaust. It makes you use a suction gun. IDIOTS!!!
Old Apr 21, 2008 | 10:37 AM
bkomlyn's Avatar
Don't forget to keep an ample supply of "warranty lube". KY or Vaseline are great but in an emergency spit is even better than nothing
