Rock rails question...
Hey y’all. Just became the owner of a ‘17 JKU sport. It has some side steps bolted on that I don’t like. Was hoping to just put the rock rails on.
found a set locally cheap that I’m hoping to pick up. But as I’m reading it seems they don’t stop at the body lines? Runs into the rear fender well?
right now the Jeep is stock. With stock tenders and tires and height this shouldn’t be an issue but when I lift and go to 35s and replace fenders then I’ll want/need to trim them? That right?
^They're not wrong, mine are trimmed at both ends, not a huge deal and it's easy to trim them while keeping them looking good.
Hey, I'm on the other side of town from you......if you are interested, I have a set of Rubi rails that I welded tube to with some flat stock to provide a nice step and was durable for banging against the rocks. They are trimmed already and I've welded a cap in place so water/mud doesn't get down in the rubi rail. If you have an interest, PM me and I can send you a couple pics. The forum is having issues at the moment so can't upload here.
Sounds like JKU Rubicon rock rails ??? yes they extend beyond the body lines... YES you can trim (cut) to length to match the body line. I recall seeing a video (maybe Utube) on this process.. It simple -- mock up the rails, mark off the cut line (match body line) pull off the end cap plug .. make the cut. slight amount of Black RTV on the cap - re-install the cap plug.
