View Poll Results: What rear rotors to buy
Mopar OEM
1
25.00%
Crown Automotive
0
0%
Slotted (various companies)
1
25.00%
Other, please include response in thread
2
50.00%
Voters: 4. You may not vote on this poll
Rotors Help !!!!
Old May 10, 2014 | 08:53 PM
onecrazyfuq's Avatar
Default Rotors Help !!!!
Hello fellow jeepers, My 08 wrangler 2DR finally needs its first set of pads and rotors (approx 40XXX) I am coming from the VW world where everything is cross drilled and slotted. For the front ive decided on the teraflex big rotor kit. But for the rear I was planning to keep it stock. I was wondering what brands everyone is using for the rear, and if slotted is worth it. From what ive seen mopar rotors are approx 80 dollars a rotor, and crown automotive are approx 60 a rotor. All advice is appreciated, I am planning to order by the end of the weekend. Thanks everyone
Old May 10, 2014 | 09:37 PM
Jeepstin12's Avatar
I am a big fan of EBC brake rotors and pads. Green stuff pads. Had them on my dodge ram, land rover, racing quad and utility quad. I noticed an improvement on the dodge and land rover. I installed the dimpled and grooved as opposed to drilled and slotted. The larger surface area still allows more cooling and being the rotors aren't cut through, they are stronger. I Stayed away from slotted as I have heard from many about rotors cracking. Various brands on that issue, not just one brand.
Old May 11, 2014 | 02:39 AM
OH9JK's Avatar
JK-Forum Ambassador
I typically look for Bendix, Wagner or Raybestos brake parts.
Leave the slotted, drilled, whatever stuff for the tuners and race cars.
Old May 11, 2014 | 02:58 PM
Towzone100's Avatar
I would go with EBC. I would also recommend dimpled and slotted rotors. They dimpled part of the rotor will help with gas created by the braking action. The slots dissipate heat. I use them with factory pads and it works great. No brake fade and better stopping power. I have done so on all my Jeeps for the last 10 years.
Old May 11, 2014 | 03:00 PM
Jeepstin12's Avatar
they have slotted and grooved. When I put them on the land rover, too heavy of a vehicle for slotted. They only sold grooved for that rig. Given the JKs aren't exactly little Hondas in the weight class, I would net run slotted. Grooved has shown to dissipate as much heat while maintaining strength.
Old May 11, 2014 | 07:18 PM
Ok so now that I've decided against drilled or slotted. How about what companies OEM rotors is everyone running in the rear. I'm leaning towards crown rotors. Any suggestions
Sent from my phone that Obama doesn't pay for!
Old May 11, 2014 | 07:36 PM
Jeepstin12's Avatar
Originally Posted by onecrazyfuq
Ok so now that I've decided against drilled or slotted. How about what companies OEM rotors is everyone running in the rear. I'm leaning towards crown rotors. Any suggestions Sent from my phone that Obama doesn't pay for!
no opinions there. I will be doing EBC all the way around when I need a new set.
Old May 12, 2014 | 03:45 PM
themoneyshot's Avatar
ebc sell an oem style rotor as well.
