Rough Country 4" short arm lift 2dr
I am looking hard at this lift for my Sahara and want to know if anybody has installed and had used off road.
Building my Jeep for a Rubicon run next summer and have had a 4" RC lift for my older Toyota and liked it alot. Thoughts please
Well my experience is this with a two door
When you go higher than a true 4 inch lift
Must haves in a two dr
Driveshaft front recommended Rear
8 arm for correct geometry and I'll debate anyone on this. Higher than
Draglink flip kit
Front and rear trackbars
Extended rear end links
Draglink flip kit
Draglink flip kit
Draglink flip kit
Originally Posted by Atch
For a 2 dr I've heard the rear ds goes out before the front
The kit does come with new track bars. As for the drivelines I should be fine for daily driving until next summer before extreme wheeling right? I have a 2dr btw.
I recommend if you go over 3 inch suspension you should also be looking at a drag link flip kit as well.
Are you just going to just 35 inch tires? what are you looking at purchasing?
Plus do you disconnect or are you running short front end links? Whats your shock length. See all these are factor, If your running 3 inch or under or short links or shocks it will help keep your front shaft from rubbing
I am wanting to go 4" lift, 35" tires, 373 gears right now, later wanting 4:88. Six speed tranny, wanting e lockers front and rear, have open diff in front and LSD in rear.
Wanting to spend 4 grand or less of possible before next season at the Rubicon Trail.
Been something I have wanted to do for a long time and finally I have my Jk and want to go badly but I want to be prepared and have one hell of a off roader for a person with a limited budget.
Thoughts
Thoughts
