Royal Purple Fluids
Royal Purple Fluids
I have a 2010 Unlimited Sport with just over 50,000 miles I purchased used a little over a month ago. Next oil change I was thinking about going with Royal Purple....also, gradually swap over other fluids to Royal Purple. Is it worth the extra cash? Or what else do you guys recommend? Thanks!
Depends on what you want to do with your vehicle. If it's a high performance or extended change intervals, then yes, maybe Royal Purple is what you need. If you plan on regular interval changes and not moding your engine to max out it's capabilities, then I would go with a good, economic choice. I run Mobil 1 as I hear good things about it, it's worked out for me, and my change intervals are like clockwork. Hope this helps.
Cheers!
Cheers!
