Rubber power steering hose x2 failure!
Same with them. They have the same type metal ends that are subject to the same type temp issues. If you're experiencing what I think you are, it just looks like there is a little wetness between the hose and metal collar that's clamped over the rubber hose end, right? That's really considered a normal hydraulic condition. New hoses might stop it for a while, but it WILL happen again. And again, and again, and again.......
incidentally, The high pressure hoses located on top of the radiator are completely dry.
Hey Redneck just a question. When the hoses are replaced is there allot of fluid loss? Will they have to top off?
The parts for my Jeep are finally in (Steering stabilizer shock, two lower transmission cooler hoses ). Just in time too. Both the transmission cooler hoses are pissing fluid pretty bad now. I hope it was just a defect from factory. Having to replace those hoses every year would be retarded.
Must be a problem though because it took 2 1/2 weeks to get them in (Back order). The service rep said they have been replacing lots under warranty.
I suggest you check them........Let me know your findings.
Mine goes in Monday for the same thing. I was changing the oil and I always look aorund when under there. And I noticed wetness between the hose and metal collar that's clamped over the rubber hose end. I will find out then if they have the part in stock or have to wait.
Didn't happen to me... but when I was getting my oil changed just before Christmas I was yapping with the service advisor and he was saying they were backed up and going nuts with people coming in without power-steering...
Basically, what he said was when it gets cold people were just jumping in their cars and taking off without giving the power steering fluid enough time to warm up. The cold fluid pops the lines off and then there ya go, no power-steering.
I dunno... cause that's pretty much what I do. Hop in and go. The only warm up time I give it is if I have to scrape the windows or wipe snow off them.
You are correct. Mine were leaking a little excessively. They were dripping fluid on the floor. (Is that normal?) I can understand a little wetness at the hose/ collar junction but mine was leaking onto the floor. I have never had an issue like this with any other vehicle.
Well. Low and behold I just saw that the same cooler lines that the dealership replaced are leaking again.
So It is going back in on Monday. this is strike 2. One more and we will be filing for lemon law
