Rubicon differential mode when disengaged
Is the rubicon rear differential a limited slip or open when disengaged?
I'm trying to decide if my next jeep is going to be a rubicon or not. I don't offroad much at all any more. I like the 4.1 gears and dana 44 up front but don't want to give up my limited slip in the rear differential. I'm only going to be running 33s so I thought i could make do with 4.10 gears. Perhaps it would be better to just get a unlimited sport model and then regear.
They are open until you press the button, then they are fully locked. The factory limited is clutch driven and will wear out.
The factory rubi lockers may have their own issues, but between the two, the lockers are the much better choice.
Also, is an E-locker meant to be engaged all the time when off-road or only when you need extra traction in a short distance?
Leaving them on all the time off road is hard on the system unless you only go in a straight line.
I have two wangler four door automatics a Rubicon with lockers and Sahara with a SLD. Driving in 6" of snow I couldn't tell the difference witch one was better traction. Once I locked the Rubicon axles, big difference. I think now I should of gotten another Rubicon instead of the Sahara. But I do get 5mpg more in the Sahara. 3.73 gears vs. 4.10 and more road friendly tires.
