rubicon take offs question
Is it really worth it I have a x and well its a bit of a rough ride I here the take off make it ride better .... Is it worth and will it give me lift
I bought some takeoff shock and springs, but ended up only installing the shocks. Since my '08 X 2-door has the rubi wheels and towing package from the factory, it already has the same springs and ride height as the 2-door Rubi. The JKU Rubi springs are stiffer, not taller. So the reason why you get an extra lift out of it is because they don't compress as much, which means your ride is going to suffer unless you put some heavy bumpers and skid plates on. I decided that I didn't want to put up with the stiffer ride for only about 1" lift. So I just put the Rubi shocks on. Oh man, what a difference that made, both on and off road! It's a little firmer over minor bumps, but far more forgiving over big ones. Also, there's less body roll with sudden maneuvering. Well worth the money I spent, even if I did leave the heavier springs on the shelf.
The shocks and coils? Yes, if you can get a good deal on them
And what coil #'s are you on now?
Look over the threads where people have upgraded to rubicon stuff.
https://www.jk-forum.com/forums/show...uestion/page44
https://www.jk-forum.com/forums/show...ngs-and-shocks
https://www.jk-forum.com/forums/show...-Upgrade-Issue
Any idea if upgrading Sport shocks/springs to Rubicon ones will potentially void the warranty on suspension parts? Wasn't sure since I guess they are OEM, just for a different model. Doesn't really matter, just interested.
Originally Posted by jp523
Does the Rubi stuff improve a Sahara as well? Just curious. I have an 09 unlimited Sahara and want to lose the "rake". Not going to lift it, but am considering front spacers. Thoughts?
