Running Hot
Old Nov 14, 2010 | 05:08 AM
Road Warrior's Avatar
Default Running Hot
I have a 07 JK and I get this feeling that it runs hot even though the gauge shows the needle stright up,but I get that smell outside should put in a differnt thermostat--I have a cold air in-take installed if that makes a difference
Old Nov 14, 2010 | 05:15 AM
Ghost63's Avatar
I wouldn't start replacing parts until you determined what, if anything is wrong. If you are smelling hot engine coolant, but the temp guage reads normal, then I would start by looking for coolant leaks. Small leaks can get on hot parts and give you that "overheated" smell.
Engines that are overheated often start pinging due to the increased cylinder head temps, and typically have less power. A bad thermostat can cause this, but again, I would make sure that the engine is truly overheating before changing parts.
Old Nov 14, 2010 | 05:26 AM
JKdewd's Avatar
Default 2007
I have a 2007 with 22k miles on it.. garaged.. babied.. I smell coolant.. I think it's just a POS chrysler and it's the way it is.
Old Nov 14, 2010 | 06:01 AM
TORN's Avatar
I would check coolant levels and proper mixture first.
Old Nov 14, 2010 | 06:11 AM
Yea I did that
Old Nov 14, 2010 | 06:19 AM
ronjenx's Avatar
Buy or borrow an infrared temp gun and point it at the thermostat housing when the engine is warmed up. If the temp reads between 190°F and 215°F, it's normal, and the gauge will be straight up.
