Running Low on Antifreeze
So I got some new parts in for my JK, one which being was a hood lock, as I started to look around, I noticed My Antifreez level was extremely low
I barely have 4000 miles on it and did not have the temp light go on...I am wondering this can't be normal right? It was due for a 27point maintenace check , which I have not got around doing yet.. Probably done when I get my brakes checked for the Recall
Anyways
I went offorading ( nothing major) about a month ago and was wondering if this had something to do with it? I filled it up either way
Any ideas why this is?
Anyways
It's possible that some leaked out if you were that steep. I just had this exact same issue but mine turned out to be a bad water pump. Look under you engine and see if there is any coolant. If it's clean, most likely it would probably be from offroading/evaporation. You can then add more to the resevior and track it just to be safe.
