Rust
Old May 30, 2013 | 08:14 AM
CrazyHorse's Avatar
Default Rust
I'm looking to hear from 07-08 owners with rust problems. Control arm brackets, track bar brackets shock mount brackets ETC. any input would be helpful, thank you
Old May 30, 2013 | 10:18 AM
d.ibarra's Avatar
I have an 07 sahara. I had some surface rust on on stock hardware but nothing serious and I replaced hardware when I put in new lift. I'm not sure what ur looking to get outta that comment but there u go haha
Old May 30, 2013 | 10:23 AM
SaFFFari's Avatar
I bought a pre-owned '08 that came from Connecticut. Didn't find much rust under the jeep (at least not anything to cause concern). I did however find rust in the interior. All the bolts for the seats have rust and the door hinges have bubbling paint (which leads me to believe there is rust under the paint). I haven't addressed either yet.. But will in a few days, with some raptor liner that I just bought.
Old May 30, 2013 | 11:55 AM
klankster's Avatar
A little newer than requested but I bought an 09 with 50k on it last summer, I live in NY so it sees plenty of salt. The shock hardware was a little rusty when I replaced the shocks last fall. I replaced the bolts on the control arms and trackbars with a grade 8 kit a few months ago and everything came apart easy with no rust. Like mentioned before all the bolts that hold the seats down are rusty though. There is also a little rust starting to bubble up at the sheet metal seams under the carpet. That will be fixed soon though with some chassis saver and monstaliner.
If you live anywhere with salt, never-seez is you best friend.
Old May 30, 2013 | 12:15 PM
CrazyHorse's Avatar
Thanks everybody....... My reason for this post is That a friend / co-worker is trying to find out common rust problems on JKs in hopes to make replacement parts
Old May 30, 2013 | 03:13 PM
redwagon's Avatar
Door hinges have bubbled because they are aluminum hinges against stell doors on 08's
blast them and cover with bedliner
Old May 30, 2013 | 06:47 PM
mbanik's Avatar
I have 90k and 6 New England winters on an '07. Surface rust here and there on the frame but nothing serious.
The tub seams underneath are starting to show some rust. I'm going to spend a weekend with a gallon of chassis saver and hopefully go another 6 winters.
Old May 31, 2013 | 11:15 AM
Christine's Avatar
The only rust I've noticed is my door hinges. I can tell they are rusting under the paint. I haven't fixed them yet. I under coated my Jeep two years ago and haven't had any problems.
Old May 31, 2013 | 03:05 PM
Ryan0260's Avatar
You can get the hinges fixed under warranty..
Old May 31, 2013 | 07:05 PM
NLangan's Avatar
My '07 has a hinge bubbling bad, I'm not original owner though. Am I outta luck?
