Seasons Changing... winter tires?
Well, I just found out the Toyo G-02 Plus is unidirectional. That bites. It means no decent rotation, and if I blow a tire, I might have to run the spare backwards. :-P
Now I'm looking at the Toyo A/T or even the M-55 (that can be studded).
Can anyone suggest another "all position" (aka non-unidirectional) tire that would be good for winter -- and is available in the larger sizes like LT285/75R16 (33x11.5")?
Thanks,
js.
Thanks,
js.
Nokia makes excellent wintertires which i have been using with my Defenders.
Can you use ice-studs at Canada like we do here ?
And when i go offroading to snow nothing beats good snow-chains, great traction.
js.
Run COOPER DISCOVERY M&S tires on my Trucks & cars here in Revelstoke, BC .
Revelstoke gets lots of snow avg. snowfall/yr 12 to 20 ft in town......higher elevation (50 to 75 ft)- Selkirk mountain range. So, we get snowfalls some days 2 ft accumulate on the ground in 24 hours.
Great for Skiing and Snowmobiling but not so great if you have a 2wd vehicle. I have been happy with my Cooper Discovery M&S tires (studded) they have never let me down,good price, great traction, good wear (currently have 55,000km - 4th winter) and I should get about 65,000...not bad for a softer rubber tire.
I usually get two sets of rims and keep the winters on a cheaper set & run M/T's on my good set of rims. Save money from remounting each year.
Once I we get our Jeep we are getting a set of Cooper Discovery M&S if they come in a similar size to the stock tire. if not I am looking at Toyo Open Country A/T as this tire is studdable and comes in 18 inch size.
Buying Maxxis Bighorns and adding studs. Problem is, wih the new TPMS, it is going to be a royal pain to switch wheels/tires. I may have to run this set-up year round. Luckily in Alberta, it isn't illegal, but will be annoying for me.
I always found the BFG AT to be a good preformer in the snow, I try to avoid the ice cause I hate being just a passenger when I am sitting behind the wheel.
I have always been comfortable with the AT's, but for what it may be worth, I have used them on full size Blazers and Broncos, so the increased weight may play a slight part in the traction I felt they afforded.
And you know, here its 8 months of winter, followed by 4 months of ruff sledding.
Get yourself some Steely Rims that fit the Jeep and buy some tire sensors to place into the tires. Problem solved. Or you do what I have done in the past is use the stocker rims and place the winter's on the stock rims. Then buy some nice summer chrome/black rims & get a second set of tire sensors for your jeep!
I have done this and have gotten 4 winter uses sometimes 5 on the winter tires and 3 or 4 years use on the M/T tires I have for Spring, summer & fall. With the savings on mounting and remounting/balancing you basically have paid for the rims in 4 or 5 years.
I drove my 2 Door X with stock Goodyears threw the nastiest part of winter here in Brunswick, Maine, and you can go from snow, nasty slush to ice all in one drive and in 4 HI the stockers did just fine. Once you hit just ice you are in the hands of the ice, but I think that is pretty much with any tire, even the best winter tires. I am interested to see how the stock AT's on the Sahara do this winter.
I live in the "snow belt" of NE Ohio, so we get more than our share of nasty weather, and I've had great luck with the BFG A/T KO on my TJ. Great all round in snow, ice, and wet weather. A big plus is that they wear well and are very good off-road. THey will be going on my JK when the stockers wear out. Based on my experience with the stock RSAs in the sand I think they will be adequate in heavy snow though. I should find out soon...too soon
