seat height adjustment ????
Old Jan 23, 2010 | 05:28 AM
  #21
topdog1308's Avatar
I thought I was losing it seems to be a regular problem..
Old Jan 23, 2010 | 05:39 AM
  #22
orangeJK's Avatar
same deal here, usually drops about 1 or 2 pumps down .
Old Jan 23, 2010 | 07:02 AM
  #23
Widewing's Avatar
Originally Posted by jeepnpr
The seat height gremlin does not leak down or lower your seat. The problem is that when you get in and out you are compressing the seat edge which in turn cranks down the lever. It is a slight amount but after getting in and out a few times the seat will be lower. Blame it on the butt
Really? So, when it drops by itself with no one sitting in the Jeep for several days, whose butt do I blame?
My regards,
Widewing
Old Jan 23, 2010 | 09:11 AM
  #24
earnsdorff's Avatar
I had to add I have the opposite problem - I wish mine would go lower!
Maybe Jeep should have put height requirements on the purchase of a JK cause they seem to have problems making parts that actually work!!
Old Jan 23, 2010 | 09:16 AM
  #25
Fathom's Avatar
Originally Posted by Basic13
Props to the first person who posts a "write-up" on removing the stupid, worthless handle. According to someone there is just a c-clip that holds it on for easy removal?
The height adjustment handle is very easy to remove. I removed mine to paint them.
If you see the large circle in the middle of the handle this can be pried out (VERY GENTLY! I broke a small clip molding off when I did mine but silicone glue came to the rescue). Once the cover (circle) is off there is a large "torx" bolt that holds the handle on. All the rest of the smaller handles use the "c" clip method but the large height adjusting handle uses a bolt. Simple!
Old Jan 23, 2010 | 12:54 PM
  #26
JKlad's Avatar
Yeah, it's probably the same plastic c-clip that holds the transfer case lever cable on!
Old Jan 23, 2010 | 01:15 PM
  #27
Basic13's Avatar
  #28
Basic13's Avatar
Your awesome. Thanks!
Old Jan 23, 2010 | 04:41 PM
  #29
JMP8562's Avatar
i always thought that it was due to all the pot holes and bouncing up & down on the seat
Old Jan 23, 2010 | 05:06 PM
  #30
curtis's Avatar
wow glad to see that i'm not the only one with this problem..........
