serious oil leak
Old May 8, 2010 | 05:08 PM
JasonS8959's Avatar
Default serious oil leak
a few oil changes ago i when i changed my oil only 2 quarts drained out. since then i have checked my oil level weekly and seem to have to add oil often. i changed my oil today and only had 4 1/2 quarts drain and i just added oil to it about 2 weeks ago. so i got to looking around and it looks like oil is coming from the pulley just above the oil pan. does anybody know what this pulley is and if oil can leak from that spot. thanks in advance.
Old May 8, 2010 | 05:14 PM
runit3's Avatar
Are you sure the oil isn't leaking from the oil filter (located next to the pulley). The old oil filter gasket can get stuck on causing leaks when the new filter is screwed in on top of it.
Old May 8, 2010 | 05:46 PM
JasonS8959's Avatar
positive that its not leaking from there.
Old May 8, 2010 | 06:13 PM
jeepoholic's Avatar
Is it still under warranty?
Old May 8, 2010 | 07:00 PM
Widewing's Avatar
It could be a front main seal, or more likely be leaking down from the front timing cover.
There is a TSB out for porous seal surfaces on front engine covers. Mine (a 2008) had this problem and the timing cover was replaced under warranty.
TSB 09-008-07
Old May 9, 2010 | 08:11 AM
JasonS8959's Avatar
no more warranty
Old May 9, 2010 | 01:21 PM
jeepoholic's Avatar
Originally Posted by JasonS8959
no more warranty
That suck's, hope you can find the problem with out it costing you a arm and leg.
