Shakes at 70 mph.
Old Feb 4, 2010 | 08:12 AM
mighty-banana's Avatar
Default Shakes at 70 mph.
I was wondering if anyone has had a problem with your Jeep shaking at 70 mph. I don't think I had this problem before I towed my bike on a trailer. Or before I put some new tires on there. The tires I put 265 70r17 or 75r17. Not really sure. But has anyone had this problem or should I take it to be checked. Thanks.
Old Feb 4, 2010 | 09:09 AM
EmbarkChief's Avatar
Check to make sure you don't have some mud stuck on the inside of your rims. If that's not the culprit and you are running the correct tire pressure I would take them back in for re-balancing.
Old Feb 4, 2010 | 10:11 AM
JKRockStomper's Avatar
x2 on re-balancing
Old Feb 4, 2010 | 12:16 PM
JK-UTE's Avatar
x 3 on the rebalancing. Maybe your stearing stablizer bar?
Old Feb 4, 2010 | 12:22 PM
interceptor_1972's Avatar
Also may want to check and make sure you didn't lose one of your wheel weights...
Old Feb 4, 2010 | 04:29 PM
ok thanks. I'll take it to get re-balanced.
Old Feb 5, 2010 | 12:28 AM
greenryde's Avatar
70 miles per hour thought the speed limit was 55
Old Feb 5, 2010 | 08:10 AM
RescueGreen#3's Avatar
x 500 BALANCED!!!
Old Feb 5, 2010 | 08:39 AM
whpony96's Avatar
Without a doubt your tires are not balanced correctly. Go get it taken care of right away. Or you will be buying some new tires sooner than you wanted to..
