Shaking/vibration after 45 mph..NOT A DEATH WOBBLE
Old May 16, 2012 | 05:56 AM
rattler_thesnake's Avatar
Originally Posted by DvD88
I had the same problem since I change the wheels and tires. 45-50 mph started to vibrate. I went to align and balance about 8 times and could not find the problem. Just for curiosity, I asked em to change the wheel spacers and TAN-TAN! The problem was solved! It may be that your adapters be defective! TRY IT...
I will swap out the factory rims and tires with wheel spacers for the soft 8's i have on my Rubi and see if that is what causes it.
Does anyone know off hand, if I even need to run wheel spacers with 315's on factory rims with the Terraflex level kit?
Old May 16, 2012 | 08:21 PM
09jaykay's Avatar
Yes you will need spacers, or 4.5in backspacing.
Old May 17, 2012 | 07:29 AM
Matthewd5's Avatar
What makes the spacers/back spacing necessary, something to do with the lift?
Matthew
Old May 17, 2012 | 07:33 AM
Noxian's Avatar
Matthew
Spacers/backspacing are necessary when you increase the width of your tire over stock, otherwise your tire will rub on the suspension components
Old May 17, 2012 | 07:45 AM
isolated1523's Avatar
Any chance that when putting on the spacers, you didnt remove one or more of the small star-shaped washers/rings that come from the factory on the lugs? This could cause your spacer to not sit perfectly level and cause a very slight out-of-balance condition...
Just a thought, easy to check and free
-Adam
Old May 17, 2012 | 10:05 AM
Tx98Formula's Avatar
Mine started doing this after mudding, doesn't start till around 55-60 but at 70 it goes from a shake to move of a faster vibration, sometimes it calms down for a couple minutes then comes back. I cleaned the wheels pretty well but maybe i missed some on the inner part of the wheel.
Old May 17, 2012 | 01:46 PM
Ryan0260's Avatar
More than likely you missed some mud. It can easily throw a tire out of balance
Old Mar 9, 2021 | 05:53 AM
Michael Micolucci, Jr's Avatar
I have this same exact problem only from 45mph-50mph. I do have 2in wheel spacers, do you mean change the wheel spacers and get new ones, or re try to align the spacers i already have to fix this problem?
Old Mar 9, 2021 | 06:45 AM
resharp001's Avatar
Loved
Community Favorite
This thread is suggesting that if you have cheap spacers and not a tried and true brand like Spidertrax, Synergy, etc, that the spacer itself could be an issue with high/lo spots. It's quicker to first try and rotate your tires to see if it's any better. Usually, these things are tire-related. If it is the same, then rotate the spacers themselves from front to back and see if there is any change. Since you have a 2" spacer, I'm guessing they might just be an eBay special. That's what I'd do at least as a starting point.
Old Mar 13, 2021 | 06:49 PM
karls10jk's Avatar
It's funny this popped up. I had a little more shimmy than you'd expect with tires out of balance and while it would get better with rotating the tires (thus pointing to my balance being out....which I figured as much), it also stayed around even with changing tire pressures and positions. I was doing inner axle seals which means you're pulling the guts out of the front end and figured I'd do brakes while I was there. Lo and behold, one of my axle shafts made a crusty noise when moving it around. I took the joint out to take a peek and the first set of caps looked good. The other set was dusty and rusty- seals let go and the grease was gone. Replaced the joint with a 5-760x (2011 was the last year of that part number if I'm remembering right) and it's eliminated that little shake.
TLDR, check your u-joints, they may be bad.
