Shifter light
I am assuming you have an automatic,and are talking about the gear selector light to let you know what gear your in. I would say it should be as easy has taking the center consul apart and finding the bulb swap that sucker out and put back together.
Check out this thread https://www.jk-forum.com/forums/jk-e...5/#post4172305
It was pretty quick and easy on my '09
I think I took that off the first time when I was trying to figure out how it came off....if I recall, that bottom piece is really just superficial. I don't think it's any easier if you pry that off. Mine was a real bitch to get off the first time. I twisted and pulled and the thing didn't budge. I ended up using a strap oil filter wrench to turn that knob from side to side and then was able to pull it off.....course now it's a little loose which aggravates me.
