Side marker Fuse location?
I'm replacing my 2011 Wrangler fender flares and the driver's side LED isn't working but passenger side is. I reinstalled the stock bulb and i'm not getting any power to it. Does anyone know the fuse location for the driver side marker? Are both front and right side markers on the same fuse? Thanks.
I lost my passenger side light and it was the cable that was bad. Take the cable from the passenger side and hook it up to the drivers side. See if it lights up. If it does the cable is bad. And if it is the cable I have one laying in my garage that I can send you for free if you pay shipping.
Sorry it took so long to respond. I did exactly that and it still didn't work. I checked the wires behind the plug that the small harness plugs into and found that somewhere further back I have a bad ground. Rather than spending all day tracing the ground for this particular side marker, I just made up a ground wire and attached it to the ground screw on the fender about 6" away from the plug. I then just used the stock power wire and tested. Light came right on. I shrinked wrapped my connections and installed the fender flare, all is well now.
