Small and large and GASCAP
Old 03-07-2017, 07:15 PM
  #21
EHarris's Avatar
Originally Posted by Spytec128
Have you checked the vapor canister to make sure it is not cracked? The gas tank system is a closed system so a cracked canister can cause your symptoms.
Yes the canister looks good to me. Would it be some type of connector or regulator that attaches to it? I would assume with all 3 coming on immediately that it has to be a bad part somewhere.
Check out the link above and tell me which parts to throw money at. Like I said I can get these for cost so I wouldn't mind doing the entire thing but it doesn't make much sense to do that.
Old 03-08-2017, 04:24 AM
  #22
Spytec128's Avatar
If you are positive it is not the gas cap or vapor can then it is going to be a little harder to find the problem. Sounds like a line could have a hole in it or a connection came loose. If the lines are good and the connections tight then there has to be a gasket leak. Check the entire fuel system from the gas cap all the way through the tank and up to the fuel rail on the engine.
Old 03-08-2017, 10:59 AM
  #23
EHarris's Avatar
Take a look at the picture I posted above in the previous thread. That comes from my gas tank to the filler hole. Could that little leak be it?
Old 03-09-2017, 03:42 AM
  #24
Spytec128's Avatar
I doubt it. If all three codes are popping up at the same time then it is going to be something big. I believe it is going to be a crack in your canister or the sensor.
Old 03-09-2017, 11:32 AM
  #25
EHarris's Avatar
Ok I can get the parts for cost so I guess I should just order all 3?
Anything else I should purchase to get this solved once and correctly.
Old 03-09-2017, 11:45 AM
  #26
sahara4me's Avatar
Instead of throwing parts at it take it to a shop and have a smoke test done on the evap system, if there is any leaks it will show where it is, saves a ton of time and money buying parts over and over...
Old 03-09-2017, 02:08 PM
  #27
EHarris's Avatar
I hear ya on this but I may be able to get the canister and other parts for under $100.
Smoke test is gonna be easily $100 or more. Was just hoping to hear from someone that it was a common problem and to replace part "X" and all will be good to go.
Otherwise smoke test it is for sure.
Old 03-09-2017, 02:59 PM
  #28
pbeabout's Avatar
The white thing in your picture seals to the canister with an o-ring. They go bad sometimes. I think that part can cause problems itself I just don't remember the correct name for it. I also think there are some hard lines up by the battery that crack sometimes that can cause those codes as well. Good luck
Old 03-09-2017, 05:44 PM
  #29
EHarris's Avatar
by "hard lines" do you mean the ones that kinda look like 1/4 copper piping? Would any of this be covered under my lifetime powertrain? Im assuming the emissions system is not part of it.
Old 03-09-2017, 06:04 PM
  #30
pbeabout's Avatar
No, I meant the hard plastic lines. Trace them forward to the engine compartment. The problem could be there.
Quick Reply: Small and large and GASCAP
