Smoking brakes
Smoking brakes
In the way to work this morning I noticed the jeep (09) didn't seam to have the normal get up and go. When I got to work I could smell the breaks and there was a lot of smoke from the rear driver side. It was fawkin hot, the driver side rear was hot to touch but nowhere as bad. When the smoke stopped I pulled the tire off the pass side, thinking the calliper sliders were stuck. They were free. The e break wasn't on and was all intact. I loosened the bleader screw an could push back the piston by hand. Pads are new 1 month ago and still intact. Don't see any oblivious things that would cause the break to stick. Any ideas?
When a brake heats like that it is 99% the caliper pistons not returning after pressing and releasing the brake pedal. The 1% is check the caliper float pins to see if they are free. Replace them anyway with the caliper. Most people do not change the brake fluid every 2 years and this puts moisture in the fluid (its hygroscopic) and creates a corrosion ring in the piston hence stopping it from returning to rest position.
Yep, it's a necrothread back from the dead, but I'll throw in the brake hoses. It's very common on the JK for the hose to breakdown inside and a flap almost forms like a check valve, not letting the fluid pass back and keeping pressure on the pads.
True another possibility but if the fluid is a dark color then I would go more to caliper damage. Ghost raises a good point that reminds me what I do with the brakes and that is be proactive. I have hard lines lowering in the rear, for the small lift, with the stock flex lines that are probably original. I am going on a 5 day overland trip in mid August and those lines are being changed to longer TF lines and the hard lines being returned to original location. Good insurance.
