so pissed at the dealership
Old Jun 9, 2011 | 03:39 PM
thrshr01's Avatar
Originally Posted by kik
Is it possible that it's as simple as a bad gas cap or malfunctioning evaporative cannister? Because it sounds like they guessed and replaced everything else. It might actually be something simple.
That would store a different code. It sounds like something is either fouling up his 02 sensors or there is an intermittent problem in the circuit because they keep on going to the same components (I've read his other post about this problem).
Issues like this usually is something simple that an overzealous tech with a nice toy (scanner) sometimes overlook. Not saying this is the case with his situation but it happens to the very best of us. A second opinion is always a welcome hand. I asked you to contact Chrysler not to hang the dealer but maybe get one of their engineers or top tech in the nation involved.
Old Jun 9, 2011 | 03:41 PM
thitalian97's Avatar
The gas cap isn't loose on my 10 Rubi. I would definately replace that gas cap. If they don't seal just right it will cause your check engine light to go on. What do you have to lose at this point by replacing it and ruling it out?
now when i say loose i guess it only turns one click to the left and its off. seems almost too easy. ive thought about replacing it just for shits and giggles to see what happens. your right nothing to lose
Old Jun 9, 2011 | 03:44 PM
i have this suspicion that it is indeed the catalytic converter, and seeing as how my emissions warranty is almost up it seems like they are trying to stall so that they dont get stuck with the bill. O2 sensors dont go bad for no reason. especially not repeatedly. there has to be a root cause to this
Old Jun 9, 2011 | 03:50 PM
kik's Avatar
kik
I understand your rational and frustration with this. However, if they replace the cat under the emissions warranty they will be paid by Chrysler. Just more billable hours. What I also find interesting, is that did this start to happen after they replaced your fuel tank? If so, maybe they didn't hook up one of the lines properly. But, like was mentioned, they should have a code for the problem.
Old Jun 9, 2011 | 03:54 PM
no i only had the fuel tank, the first one, replaced about a month ago. this has been a problem since last october
Old Jun 9, 2011 | 09:09 PM
JKlad's Avatar
Is your motor burning oil, as this will eventually kill the O2 sensors & foul the cats?
Old Jun 9, 2011 | 09:50 PM
vandegrift's Avatar
thats exactly what ive been thinking. that theyre just dickin me around. that they have no idea what the hell theyre doin
I hate to say it, but welcome to the club....
I just try to upgrade anything that goes wrong, with something better than stock; so I don't have to ever darken their doorway again. I hate dealing with those idiots.
They never try and help you when they stand to make more money.
Old Jun 10, 2011 | 04:11 AM
Yankee's Avatar
That was about to be my question also.
Old Jun 10, 2011 | 06:02 AM
bfreebern's Avatar
I had this happen with my Trailblazer as well. Cat clogged, causing my manifold to crack and jacked up the O2 sensor.
My suggestion would be to take it to a muffler shop and have them check it out, for some additional support. Once you know what the true issue is, you'll have more ammo for your dealership.
Old Jun 13, 2011 | 08:59 PM
Well I've heard back from jeep. I have a case manager and number. Sounds like they're taking me seriously. Hopefully ill get to the bottom of this soon
