Soft top flying around
When I go in the freeway where my rear doors are they beginning piece where the window begins starts flapping around any ideas how to make it not ?
are you talking about where the window wraps around and clips into the door surround? Can you snap a picture of where you're talking about?
Yep, as mentioned above it sounds like your window panels aren't securely wrapped around correctly. Definitely post a pic or two please.
It is likely that the window panels aren't securely wrapped around correctly. That piece that fits into the forward vertical channel has to turn one-quarter turn further, and then get stuffed into the channel. IIRC, the sewing seam must be at the corner, and not about a half inch back from the corner.
