Soft Top Seam?
Old Apr 16, 2008 | 06:07 AM
wayland1985's Avatar
Default Soft Top Seam?
So, this is going to drive me crazy all day, until I can get back to my jeep to check it out again.
I just got her back yesterday for some leak and sunrider work. While leaving my jeep today and grabbing my back out of the backseat, I noticed at the seam a silvery set of dots. I was in a rush so I couldn't test it, but I'm thinking it was sunlight coming in .
Are the soft tops stitched at the seam? I though they were heat welded from earlier posts. Am I imagining things, or am I looking at possible new leaks???
Old Apr 16, 2008 | 08:35 AM
RubiBurst's Avatar
Wayland,
It is sunlight. Just wait until the next big rain and feel above the soundbar. It will be wet. My top was replaced under warranty. BTW, it is a heat seal.
Old Apr 16, 2008 | 08:56 AM
crazyhorse02's Avatar
Originally Posted by SlyX26
Wayland,
same here your dealership should replace that without giving you to much hassle
Old Apr 16, 2008 | 09:40 AM
And they finally got the sunrider latch to line up.
Old Apr 16, 2008 | 02:11 PM
So, they're definitely pinholes, but I'm wondering if they'll even leak??? I tried pouring some water over the area, and they seems to keep water out. I guess I'll have to wait for the next rain storm to check it out
Old Apr 18, 2008 | 04:00 PM
Brad2893's Avatar
If you can't get it replaced, maybe use the same tape as manufacturers use on Gore-tex and other fabrics. Works well.
Old Apr 18, 2008 | 06:34 PM
Matt D's Avatar
Had the same issue...the leaking progressivley got worse....replaced under warranty. The new top seem a lot better. No more leaks
Old Apr 23, 2008 | 08:58 AM
RubiBurst's Avatar
Trust me...they will eventually start leaking. In heavy rainstorms, a considerable amount will find its way in.
Old Apr 23, 2008 | 09:35 AM
Offroadme's Avatar
you can use Nitwax too. you use it to water proof the seems on jackets like north face and mountain hardware. the stuff works great just roll it on the seems and let it dry.
Old Apr 23, 2008 | 10:04 AM
Eh, if it starts leaking, I'd rather have it replaced than having to wax it. At least while I still have a warranty
