Soft tops
Old Jan 8, 2014 | 08:36 PM
ckirk11's Avatar
Post Soft tops
Does anyone know if a 2009 jk 2door soft top and hardware will fit a 2014 jk 2door?
Old Jan 8, 2014 | 08:55 PM
woodyvw9's Avatar
Veteran: Coast Guard
I think as long as you have the door surrounds from the 09 you should be good to go.
I think they changed the top in like 2011 to a cable stay instead of the web straps, but I think as long as you have all the parts from the 09 you should be alright.
Old Jan 8, 2014 | 09:00 PM
AlexjeepVb's Avatar
I do know they changed the rear window in 2011, might all be able to work but with those things having hard enough time to seal when there right I wouldn't do it unless you have no other options or something like that.
Old Jan 9, 2014 | 06:40 AM
Jiblet's Avatar
Definitely need the door surrounds with it. The older soft tops came with a plastic header known to warp. A replacement metal version is available (like $100 DIY).
Search the forum, I seem to remember some issue with fitment that was cured by some very minor grinding with a dremel tool. Does that ring any bells, people??
Unless it's free or a real steal, I'd shop around for a newer one.
EDIT: the fitment issue was with the center loop that was moved between 08-09. Might only have effected hard tops.
Old Jan 19, 2014 | 07:44 AM
13Jeep's Avatar
Yes I have a new BestTop NX , used one season in perfect shape
I'll make you a deal
Email me at Pat@rencor.com
Old Jan 20, 2014 | 02:50 AM
BlikitSchmikit's Avatar
Vet Army
I don't know whether or not the 09's and 14's tops are interchangeable but if you need to swap out a top, I would recommend the TrekTop NX. I replaced my 07 stock top with a Bestop TrekTop - sooooo much better than the stock one. No more leaks and way quieter inside, even at highway speeds.
Old Jan 20, 2014 | 03:22 AM
GRIMM REAPER's Avatar
I have a 2013 hard top for a 4 door I want to trade for a soft top
sent from my NSA listening device
Old Jan 20, 2014 | 04:14 AM
chad s's Avatar
Originally Posted by GRIMM REAPER
I have a 2013 hard top for a 4 door I want to trade for a soft top sent from my NSA listening device
where are u located?
Old Jan 20, 2014 | 03:52 PM
Frederick, md
