sound when turning left on jk
Sounds like a bed squealing... not a lot of noise but can be heard when radio is off.... I have the extended warranty but not sure if I should take it in or figure out the problem myself first... I don't want them to be like " there is nothing wrong with your vechile blah blah blah...
Couple things that I had happen to me recently:
First squeak - bearable but there was a ujoint which only happened on one side when I turned.
Ujoint finally went and turned into a crunch.
Replaced the ujoint and it was fixed.
Another symptom was that it felt a little jerky when I turned, the steering wheel did not return smoothly.
Other recent squeak - only when I was turning, passenger side, the rubber protector on the brake line was rubbing on the shock when I turned. This is only because I installed bilstien shocks and they are a lot bigger then stock.
Tempory fix - put a dab of lubricant between the line and the shock.
Then go get a brake line relocation bracket.
What was the final answer?
Mmine makes noise while turning left, but no vibe. Just a noise like rubbing a brake dust shield. I pulled the two front tires, but everything looks fine. Pulled the back tires, and nothing seems odd? Could it be a wheel bearing or u-joint. Sadly, I don't see any rub marks on the dust shields or anything else.
Honestly can't quite tell if it is from the front or rear, but sure seems to be passenger
