Spark plug replacement
Not sure about using anti-seize on these plug threads. In most cases the new plugs are plated by the manufacturer and they specifically state NOT to use anti-sieze grease. For one thing it screws up the dry torque spec for re-tightening and you run a risk of stripping out the threads in the head, though I am not sure if that is a likely occurrence in these engines.
I had always been a greaser in the past until I had a properly retorqued spark plug back out (partially) and then blow out taking the top 1/2 of the threads. This required a re-thread with a Time_Sert kit ($$$) and expensive replace of the COP coils on that engine (it was a SAAB) but the head was salvaged and the engine runs on today.
So, use anti-seize on your plugs at your own risk. YMMV
