Speedometer with or without compass? Need replacement
Old May 13, 2009 | 10:04 AM
Woody99's Avatar
Default Speedometer with or without compass? Need replacement
I have a 2007 Sahara and I need to replace my instrument cluster/speedometer. When I call around apparently there are 4 different types. 100mph or 110mph... That is easy because mine is 100mph. However the wrecking yards ask me if I have a compass or not. How can I tell which one I have? I have a display which shows outside temp./miles per gallon/etc...
This may seem like a silly question but I just want to make sure I get the correct speedometer.
Thanks,
Woody
Old May 13, 2009 | 10:08 AM
troyeng's Avatar
Saharas come with compass. It is next to the outside temp when selected on the display.
Old May 13, 2009 | 10:12 AM
Woody99's Avatar
I thought mine did at one time but it does not anymore... I added the Trail Guide GPS and for some reason I think the compass does not display anymore. Thanks for the reply.
just found this thread so I guess it does disable the compass...
https://www.jk-forum.com/forums/show...+guide+compass
Old May 13, 2009 | 10:17 AM
troyeng's Avatar
It could be because of the compass sensor. It is located under the plastic cover above the radio. I have not used the trail Guide Gps but it looks to mount in this same area. Maybe the sensor was moved or damadged during the install?
Old May 13, 2009 | 11:01 AM
Landmarkbuilder's Avatar
Sorry about the detour in the post, but can you install a cluster with the compas/trip computer in a jk that just came with the o/s temp cluster? I know i would need the compass sensor, but is all else there? Maybe a reflash by the dealer then? Any thoughts?
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
whats the problem you are having with the instrument cluster?
Old May 13, 2009 | 11:14 AM
dmhines's Avatar
Pop the cover off your dash over the radio ... you will see the compass sensor ..
Old May 13, 2009 | 03:26 PM
Woody99's Avatar
All I can say is that its Hemi related :-)
Old May 15, 2009 | 10:23 AM
troyeng's Avatar
Good reason, I wish I had this problem.
