Spring and shock question
Does anyone know if the springs and shocks from a 2013 4 door rubicon will fit on a 2010 2 door sport? Can I expect a small amount of lift?
They will definitely fit, but you need to know the part numbers of your springs, and the part numbers of the springs your going to put on. Search "lets solve the stock springs" thread
I'm sure you've read though some of the "Let's solve the stock spring question" thread but from what I understand is the last two "numbered" digits on the spring tags are what you wanna look for. Those numbers determine how much lift you might get. I have 14's on front and 56 on back. The Springs I got from a 2010 JKU are 18 front and 59 back. for each point you should get about .5" of lift (if you are stock) soooo, with 4 points larger in front and 3 larger in back I'll get approximately 2" in front and 1.5" in back. Perfect to level it out. I haven't put them on yet but this is what I've heard from many people and from reading that other thread.
