Squeak/Rubbing Drivers side Dash
Old Oct 30, 2008 | 09:27 AM
Augie's Avatar
Default Squeak/Rubbing Drivers side Dash
I've had a squeak and rubbing noise originating rom the drivers side dash for a while now! I've tried to figure it out, but can't! Happens at any time durring driving! Anyone -somebody-anybody....HELP!!!!
Old Oct 30, 2008 | 10:34 AM
rlabbott's Avatar
Default Try tightening the A pillar bolt
Mine had a bad squeek/rattle on the driver side. It turned out to be one of the three bolts holding the roll bar to the windshield A Pillar frame.
When sitting in driving position, look up to the left. There is a hole in the plastic trim, and in there, a bolt holding the rollbar to the windshield frame. There are two more bolts you can see thru the plastic trim directly over your head, around the sides of where the sun visor boltls to the top of the windshield frame.
I would losen, spray with your favorite lube, and tighten all three of those bolts, but the noise is likely the one on the left of the windshield frame. Also, while you're at it, check the tightness of the torx screws holding the sunvisor in place.
Try this... there are other common rattles, but from your description, i would say start here. Let us know. Good Luck!
Old Oct 30, 2008 | 12:24 PM
SASQUATCH's Avatar
aha...another one for me to check out...mine is so slight but friggin irritating cuz I know it's there, only when I'm rolling does it make the sound
Old Oct 30, 2008 | 03:41 PM
Augie's Avatar
My noise comes when I'm rollin too. It comes from the dash, but will nonetheless check the pillar thanx for the help rlabbot.
Old Oct 30, 2008 | 03:51 PM
blazer4949's Avatar
My noise from the "dash" was the upper bolt that was loose near the top of the windsheild.
Sure sounded like it was the dash!
Old Oct 30, 2008 | 04:01 PM
rlabbott's Avatar
Default And if that's not it.....
Next, I would try this if your noise is not from the A pillar....
I had to fix this one too.
https://www.jk-forum.com/forums/stock-jk-tech-12/squeaking-dash-noise-cured-3743/
Old Oct 30, 2008 | 04:32 PM
Doc_D's Avatar
I had a squeak in my dash and pulled out my whole dashboard. I finally tracked it down to the clutch hardline rubbing on the firewall heat shielding in the engine compartment. I posted up the thread below and a lot of other people had the same problem. You might want to check this prior to ripping out your entire interior out
https://www.jk-forum.com/forums/stock-jk-tech-12/people-clutch-noise-please-read-43171/
Old Oct 31, 2008 | 11:32 AM
rlabbott's Avatar
Default did that too
Doc D, I did that one too. I bent the heat shield, and put split 1/4 fuel line around that clutch hydraulic line... Never again will it rattle!
