Sponsored by:
Sponsored by: DashLynx
Squeaky brake pedal?
Old 10-22-2010, 01:16 AM
BOOST's Avatar
Hey ting, I haven't had time yet with work maybe tomorrow night or sat, you just twist it? does it break off?
Old 10-22-2010, 01:45 AM
zeppo's Avatar
Originally Posted by tinglima
Hey Boost, did you try twisting the boot that goes over the booster plunger? Mine started making noise even worse today. Between the squeak in the pedal and the tailgate rattle, my JK sounds like a bucket of loose bolts. LOL!
I twisted the boot tonight and that got rid of the pedal squaek for now. I'm trying some black tape around the tailgate striker to see if that helps the gate rattle.
~Tony
If the tailgate rattle is because of a poorly latching gate you should be able to adjust the position of the striker plate ever so slightly so the latch gets a better bite on it and latches securely. Much like making sure you get the striker plate on a regular old door in the perfect spot on the jamb so the door is actually shut tight and doesn't wiggle around when closed.
Old 10-22-2010, 04:23 AM
TenForward's Avatar
Hi Boost,
You don't want to twist the boot too much. Just grip the boot like it was a microphone and twist it left and right about a half inch in both directions. I also pushed up and pulled down on the base of the booster with moderate force to kinda flex the input plunger and voila, the noise was gone. This is a temporary fix unfortunately.
Hi Zeppo,
I will try the latch adjustment as well. My initial idea with the tape is to see if I can isolate the noise to the latch. I'm pretty sure your solution will work. Thanks for the tip.
~Tony...
Old 10-22-2010, 04:29 AM
zeppo's Avatar
no worries man, I'm a big fan of simple solutions to annoying problems.
Old 10-23-2010, 11:07 AM
TenForward's Avatar
Hi Guys,
I decided to spray some silicone lube behind the rubber dust boot that covers the booster plunger and I'm happy to report that this seems to do the trick. No more noise. Hopefully it lasts.
As for the tailgate, adjusting the striker slightly forward has almost completely eliminated the clunk/rattle. I may do some more adjusting but for now, it's way better. I also sprayed some silicone on a rag and wiped down the weather strips around the hard top rear glass and tailgate opening.
Old 10-24-2010, 08:15 PM
turbotmy's Avatar
Default Fixed :)
One shot of WD40 where the pedal attaches to the booster.
Old 10-25-2010, 02:48 PM
BOOST's Avatar
Can u see this from under the dash?
Old 10-25-2010, 06:23 PM
turbotmy's Avatar
Default Yes
Happy to report......It's wide open....
Old 10-27-2010, 01:10 AM
BOOST's Avatar
Veerry niceeeeeeeeeeeee
Old 10-27-2010, 04:50 AM
TenForward's Avatar
Boost,
I take it from your post that you fixed the noise. I'm still running noise free and very happy.
Quick Reply: Squeaky brake pedal?
