Squeeky rattle in dash
Old Apr 22, 2011 | 11:58 AM
PurpleHayzzze's Avatar
Default Squeeky rattle in dash
I have an extremely annoying squeeky rattle deal going on in my dash.
Symptoms:
-doesn't happen all the time
-seems to do it more often when it's not below 40 degrees F outside.
-occurs on a relatively bumpy road; as in a not smooth surface.
-sounds like it's coming from the direction of the defrost air vents.
Before I tear apart my dash and eff something up, does anyone have any idea what that could be? Has anyone experienced anything similar? And finally, would it be a better idea to just take it into the dealer?
Thanks
Old Apr 22, 2011 | 12:00 PM
Captain Wild Thing's Avatar
I also have the same sound haven't found out what is yet
Old Apr 22, 2011 | 12:12 PM
scononie's Avatar
Default I think I found it...
I think this is the culprit
Old Apr 22, 2011 | 12:26 PM
bingote's Avatar
I know whats happening... We are all driving - very capable - rattle cans!
Old Apr 22, 2011 | 12:56 PM
ronjenx's Avatar
I had an annoying noise from somewhere in the center of the dash.
It turned out to be the A/C lines, where they come through the firewall. They were rubbing on some part of the HVAC unit.
I popped the hood, grabbed the two lines at the firewall, moved them around a little to where they finally came to rest in a slightly different position.
It has been quiet ever since.
Old Apr 22, 2011 | 01:03 PM
Sweet thanks! I'll give it a shot.
LOL, that would explain a lot.
Old May 5, 2011 | 12:56 PM
Default Fixed!
I should report that I did take it in and they found that the HVAC valve was rubbing up against the housing which was causing the squeak. Thank goodness it wasn't a hamster. They apparently put a spacer in there to keep it from ever touching again. Good times
Old May 5, 2011 | 01:21 PM
ronjenx's Avatar
Originally Posted by 97jeeperdrummer
I think I have the same rattle, can you clarify HVAC valve? Thanks!
Post #5 resulted in the same fix.
Old May 12, 2011 | 06:48 PM
Nello20's Avatar
Default question
How did you get to the A/C lines that go into the firewall?
