Stalling out...UPDATE!
Old Feb 19, 2007 | 09:52 AM
skramer530's Avatar
Default Stalling out...UPDATE!
Just got back from dealer.
Problem 1: The shuddering/rumble strips feeling was due to a faulty tire reading a 28 (*below 10 is acceptable). They re-balanced, mounted, and rotated all tires.
Problem 2: Per the TSB, torque converter is on order without having to beg and plead the dealership.
Problem 3: They have ordered me a new ignition switch...normally a $100 part, DC is puting $18.95 ignition switches in the JK's. The dealership ordered a new one and will install it with the torque converter.
This all was due to a stalling out bug that has hit many of us and led me to take it in in the first place. If it has happened to you, find a 5star dealer and have them try a new ignition switch. Most dealerships should be accomodating if it has happened to you...it happened to me twice!
Good luck!
Old Feb 20, 2007 | 05:53 AM
mslc10's Avatar
hmmmmm...sounds like what we all are experiencing IS an ignition failure or open circuit since all lights come on and my radar detector ,which is on the switched lighter , went off and came back on. This indicates to me that it has to be a fairly heavy current carrying circuit that opens causing the stall. Ignition switch maybe the TICKET !!!!!
Keep us informed !!!!
