Started out with break light on
Here is my current situation for my daily driver.
2009 JKU UNLIMITED X
1. E brake light stays on continuously
a) Center counsel removed. New Copper switch was replaced. Still same problem, no changed
Ran resistor, voltage and continuity test on both terminal points on the master cylinder plug and had 12 volts out of each terminal point
THEN New problem started
2. Fuel gauge reads Empty (have more than a half tank)
3. Fuel low indicator light on
4. When positioning the 4WD lever no lights are on stating 4 high or 4 low
NOT SURE WHAT THE PROBLEM IS.
