Starting Issue
Old Jun 20, 2010 | 07:47 PM
jeep122003's Avatar
Default Starting Issue
Can someone figure out why, when I turn the key over, I get a click every once in awhile? Does it have to do with the shifter? A week after I bought it brand new in 07, I had the Locking clip replaced for the shift interlock cable. Does this tie in? It has only started this the last 2 weeks or so.
Old Jun 21, 2010 | 03:39 AM
Darth JK's Avatar
Default here's a link to another thread
https://www.jk-forum.com/forums/show...p-Not-Starting
Old Jun 21, 2010 | 05:07 AM
Calypso's Avatar
Good info here. I should have just started with the last page first!
Old Jun 12, 2019 | 05:33 PM
Shannon75's Avatar
I will try tomorrow it has been doing it a lot the funny thing is once you start it (sometimes it can take 30min or 2min)it will continue to start its weird
Old Jun 27, 2019 | 03:11 PM
Jim553's Avatar
I’m having a similar issue starting my 2007 jk. You hear a hard click from the starter then nothing. This happens in both neutral and park. The only way to start the Jeep is pull two connectors on the ECM wait 5 seconds plug in and the jeeps starts up. Other than replacing the ECM what should I be looking at?
Old Jun 27, 2019 | 03:14 PM
Shannon75's Avatar
I didnt have anyone available at the time and was having my issue to be able to turn the key once I had someone there to help me I can go out under the hood the relays were working so I knew everything was fine there ended up being my starter I crawled up underneath it tap the starter Jeep started right up shut it off it would do the same thing to happen starter a couple times for The Hammer fired right up replace the starter vehicle has been perfect
Old Jun 30, 2019 | 11:52 AM
Allthewayjumper's Avatar
Vet Army
I've read about issues with the Neutral Safety Switch (NSS) for 2007-11 Wranglers. The factory states that the shifter cable is "self" adjusting. Whatever that means? What I have found with my JK if I cycle the shifter as far as it will go ie, example; Park to 1st then back to Reverse to go reverse or Park to 1st then back to Drive to drive.The JK continues to start all the time in Park. When I forget or get lazy and don't do the cycling the vehicle just clicks in Park again. But as with other comments before, my JK has always starts in Neutral if not in Park or clicks in Park then after cycling it starts in Park of Neutral position. Allthewayjumper!
Old Jun 30, 2019 | 02:15 PM
Shannon75's Avatar
Ended up being my starter I had the neutral switch but I got a ground cable and wired that to the alternator and it solved that problem
