Starting issue
Okay guys I need help I have a 2007 Jeep JK unlimited I used to have the problem with starting the Jeep in park I put the ground wire from the battery over to the alternator that has eliminated that problem last night we go to get into the Jeep and go to start it nothing no click no start nothing at all battery is fine you take the ignition switch and you jiggle the ignition switch or mess with the ignition switch for a few minutes and the vehicle start any suggestions and where can I get the parts if it is again ignition switch problem I don't want to buy a whole steering column can you just buy the switch I do believe it is either the switch with the tumblers or some other electrical part that is not getting good contact any help would be great
Jiggle the shift lever - works on mine
The shifter problem is solved and is definitely not the issue at this time
Originally Posted by Shannon75
(Post 4343458)
Doesn't matter if its in park or neutral drive reverse 4wd or 4low it is another condtion
The switch seems ok it hits all four spots when it doesn't start the radio light goes out when I turn the switch to off and try amd restart it comes on I am wondering if its the elictric switch on the column
Any local shop can test the starter for free also. You never know if anything else weird is happening. |
That might be the issue as I have tried Starting the car with the after market car starter and when the problem occurs it wont allow the car to start with the starter or key. Now if I can get the key switch to work then the remote works fine
