Starting problem ?
Old Sep 20, 2015 | 10:29 AM
lvisman96's Avatar
Default Starting problem ?
Hi Everyone ~ Has anyone had this particular problem ? My 2008 JK just makes one click when I try to start it...it's done this almost since I bought it (new), but very infrequently at first. I was able to put the key back into 'off' position, then try again and it would start. Initially I thought it was the battery, so replaced the battery. I now have about 75,000 miles on it and it has gotten worse...more frequent and won't start by turning key to off position and trying again. I knew it wasn't the battery (electrical problem...yet another battery's only a few months old), so I went to the next logical thing...fuel. I pumped the gas a few times and it started right up. I now have to do this every time it happens, which is quite often now. Anyone have any idea what this could be ? Thanks in advance ~Dan
Old Sep 20, 2015 | 10:32 AM
Wrangled's Avatar
Do a search for transmission range sensor.
It' pretty common. Try moving the shifter, either to neutral, or just to drive and back, should start right up.
Old Sep 20, 2015 | 06:21 PM
Wrangler428's Avatar
Auto or manual? I have an auto and sometimes I have this issue, just have to move the sifter from park to neutral and back and it starts.
Old Sep 22, 2015 | 02:42 AM
Sigman's Avatar
I had that problem and added a second ground and it fixed the problem! Alternator bracket to the battery!
Old Sep 22, 2015 | 06:05 AM
Growlz's Avatar
This helped for me also on my 2009.
Old Sep 24, 2015 | 08:29 AM
lvisman96's Avatar
Thanks everyone ! Finally took in to shop (I've a lifetime warranty); they're thinking its the redundant ground issue...if it doesn't work, I'll tell them about the transmission fix... ~D Oh, it's automatic, Wrangler428
Old Sep 24, 2015 | 08:39 AM
davids2011jk's Avatar
i hope they are able to fix it, but just a heads up, your jeep has no carb so all pumping the gas peddle is going to do is reset your oil change indicator back to 100%. key to on position, engine off and pumping the gas 3 or more times is the reset procedure.
Old Sep 24, 2015 | 08:09 PM
Aragorn's Avatar
Me too.
Also brought it to dealer at 66000 mi while under extended warranty. They replaced the starter but still had the same problem.
After I added the second ground , haven't had a problem starting since.
Old Sep 24, 2015 | 08:42 PM
loserhead4236's Avatar
+1 for adding an additional ground to the bolt on the alternator
Old Sep 30, 2015 | 04:33 AM
Wrangled's Avatar
Well I have placed a second ground to the alternator, and am hopefull that this fixes the "click, no start" problem. Only time will tell. I do know that a good ground is every bit as important as a good positive connection, and this seems to ground directly to the engine block, so it may do the trick, if the issue is a ground one. The only other thing it really could be is the transmission range sensor itself, which is not as easliy dealt with.
Thanks for the info and the pics.
