Steering issues
At low speeds in my 2015 wrangler it is next to impossible to turn the steering wheel. At speed there is no problem but slowing down to turn on to another street or parking space you have to really muscle the wheel. There is also a vibration when going over 65 mph. Could these two issues be related? Any ideas of what the issues could be would be of great help. Thanks.
There is also a quiet humming sound. Does that have to do something with the power steering? Is it still ok to drive and not cause damage to anything else until I can get it fixed?
If the wobble is bad enough you could definitely cause additional damage. I don't think the wobble is related to your steering though. I would check tire balance first to try and troubleshoot the wobble. A bad enough wobble can definitely cause damage to other components over time. I had a bad balance on my left front tire on a recent 4-day trip to Utah and back. I dealt with it and figured I'd just address it after returning. Well upon returning from the trip I discovered some play in my left lower control arm. The rubber bushings at the axle mount had wallowed out due to the bad wobble in the tire. Easy $10 fix to replace the bushings, but it remains to be seen if driving with that bad wobble may have shortened the life of any other components in my front end (TRE, ball joints, etc).
To bleed the system you make sure it's topped off with fluid, then turn the wheels from stop to stop slowly. Top it back off with fluid as needed. When the steering is easy again, or no longer needs refilled, you are good to go. This may or may not be your issue though. If the pump is bad, bleeding it won't do anything for you. Worth a shot though if you ask me. Glad to hear the wobble/vibration is gone.
