Steering off Center
Old Apr 13, 2009 | 04:14 AM
4WHLN's Avatar
Default Steering off Center
I did some trail/mud riding this past weekend and once I got home noticed my steering wheel is no longer centered. You know the "Jeep" wording is not horizontal any more. I drove it to see if it was pulling to one side or the other and its not. So my question is, is this common when trail riding and can I just recenter the steering wheel or do I need to get an alignment?
Old Apr 13, 2009 | 04:19 AM
Robar's Avatar
Q: How do I recenter my steering wheel?
A: To re-center your steering wheel, use a 15mm wrench to loosen the 2 nuts on the turnbuckle on your drag link as shown in the pic below. Then, rotate the turnbuckle clockwise or counter clockwise as needed while a friend watches the steering wheel (or you periodically check on it yourself) go back to center. Once re-centered, secure the nuts and take it for a drive to check your steering wheel. This may take a few tries to get it on 100% but that’s all there is to it.
Old Apr 13, 2009 | 04:31 AM
4WHLN's Avatar
God I hope I didn't bend anything. I did go through some deep ruts at some point so thats possiable.
Old Apr 13, 2009 | 05:43 AM
Calypso's Avatar
You weren't on the backside of the levee again, were you??
Old Apr 13, 2009 | 08:38 AM
4WHLN's Avatar
uuhh no
Old Apr 13, 2009 | 10:02 AM
4x4jkx's Avatar
Sounds like what Robar posted. My drag link is doing the same thing but it's off by maybe 1/8 cm so I'm not going to bother with it right now. Check your drag link before doing anything else. The Jeep is pretty robust.
Old Apr 13, 2009 | 11:11 AM
4WHLN's Avatar
I re-centered the steering wheel a little while ago and it seems to pull slightly to the right. I didnt notice the pull till just now. So Im guessing that I bent something or just need an alignment. How do I know if I bent something?
Old Apr 13, 2009 | 11:37 AM
Geko45's Avatar
Originally Posted by Ridin' Dirty
Did u get against something with the tie rod and bend it a little bit? That will do it. It will affect your toe in adjustment if it's bent. You can recenter it with the adjustment on the drag link but I suspect something got bent a little.....
I just had to do this myself. Drag link was bowed slightly after some hard wheelin causing excessive toe-in. Had to replace it. The bowing was only barely perceptible, but it doesn't take much to throw your alignment and wheel centering off. I did a quick re-center on the trail as shown and then had the drag link replaced when I got back. Of course, that necessitated another wheel re-centering.
Old Apr 13, 2009 | 03:26 PM
chris15005's Avatar
Mine was off center the day i bought it did was going to use the straightening procedure here but the lift cured that problem.
