Steering Stabilizer replacement
I'm looking to replace the brackets and steering stabilizer since mine has bit the dust. There are a few dual stabilizer kits for not much more than a singular replacement. Would it make that much of a difference to put the dual compared to the single? I am planning on lifting and going to 35" tires so if that makes a difference let me know. I get the death wobble pretty bad nowadays at about 55 so this needs to be changed before I go on the next trip to visit the beach. Thanks everyone!
Look for *******'s thread on diagnosing death wobble. Fix your jeep instead of applying a BandAid. A properly set up JK shouldn't need a SS at all, let alone 2. WoL and others maintain that a stock SS is good enough and certainly inexpensive.
That being said, mine's a Fox on a modified tubing clamp.
Yeah you def. need to start reading up on the death wobble causes and fixes if you haven't already; it's all on this forum. Personally I'd start fixing those things first, then I'd go w/ the Jeep swag relocation bracket and the single fox stabilizer.
Ive had the death wobble before with my two tj's and this felt the same. I hit about 55 and it feels like the tires are out of balance and then it just goes out of control. Its only on bumpy-ish not very smooth roads. I thought it was the tire balance at first and had them checked and everything was fine. The guy I go to and I looked at the steering stabilizer though and it was leaking fluid and didn't really have any sort of compression or rebound. I'll look at these kits.
The stabilizer won't cause DW only dampen it. DW occurs after something starts a wobble then loose axle parts allow it to progress. The common parts are loose bolts on the track bar or control arms, ovaled bolt holes, bent tie rod,bad ball joints or a bad steering box. Your axle should be held solid in place and a DW is the shaking of the axle itself.
The stabilizer will prevent a wobble from becoming DW to a point but the wobble itself needs to be fixed or the bolt holes will become worse and DW more frequent no matter what stabilizer is run.
The Northridge4x4 bolt kit will solve some of the issues as many of the stock bolts are a hair too small and can shift. Proper torque could be an issue. If your holes are already oval instead of round you need to address that.
I had DW on my previous JKU, at at about 50~55 mph, on a wide turn, smooth road.
The Jeep was quite new, about 4,500 miles.
The next morning everything was checked and rechecked. There was nothing that could explain the DW, except for a fault in the stock SS itself.
It was replaced with a FOX SS, and the problem never repeated itself.
Thanks GJeep, I wanted to upgrade a bit but I guess just doing a heavier duty Stabilizer would be enough for me. I'm not going to be rock crawling or anything anytime soon.
