stock 4dr X ride hight??
Im just trying to figure some things out. Can someone with a stock 4dr gimme a measurement from ground to frame? I would greatly appreciate it
, thanks in advance
, thanks in advance
11-7/8" from the ground to the frame bottom just before it starts its upward slope just behind the front wheel.
12-1/4" from the ground to the frame bottom just before it starts its upward slope just ahead of the rear wheel.
That's not the lowest point on the vehicle. That would be 8-1/2" at the transfer case skid plate.
BTW: It's stock, but I do have the 2007 S-pkg tire upgrade: 245/75R16 (I think 07s come with 17s with that upgrade).
Hope this helps!
Well, trying to guess exactly what you want:
Hope this helps!
Hope this helps!
Thank you very much I have the S-pkg as well im trying to figure out if the "6" lift kit from Bullet Proof Suspension" is really a 6" kit. Ill see if the messurments add up or are even close
