Stock Death Wobble?
Stock Death Wobble?
I've read about people with lifts and big tires having trouble with this, but I'm running totally stock (17" wheels with 255/75/17 Wranglers) and I've experience the death wobble maybe 5 times in the last two weeks!
It happens when I'm going between 45 and 60 on a curve in the highway after hitting those little groves between sections of pavement. Nothing big.
I brought it into the dealer yesterday for a normal tune up and I mentioned it. They said they couldn't find anything, but that if it happened again I'd have to leave it for a day and they'd test drive it, take apart the suspension, etc.
Anyway, I just wanted to see if anyone else has had this problem. Like I said, I've never heard of it happening with a stock setup. I'd also like to hear some ideas as what it could be from.
And if anyone has any experience with this, what's the best way to handle it. I have to pretty much stop on the highway to get it to quit, and it's terrifying. Am I supposed to break, coast, try to fight it, let it run out, or what?
JK-Forum Founder
Are you sure that you are experiencing death wobble and not your ESP activating? Just to make sure, death wobble is the violent uncontrolable shaking of the entire vehicle to the point where you feel like you are going to crash and nothing short of coming to a stop or close to it will make it go away. Is this what you have been experiencing? If not, the conditions upon which your occurances have been happening would definitely point to the ESP.
Never experienced it yet on the JK (also stock) but had it on my TJ. Likely it was a short term lease and I got rid of it.
Garage replaced the stearing stabalizer and shocks multiple times. Would always fix it short term but it would come back.
Good luck.
Good luck.
JK-Forum Founder
Oh I'm sure it's the death wobble. The whole vehicle shakes, I can't control where it's going (which is usually just straight ahead), it's really hard to slow down, and it doesn't go away until I get down to about 10 mph. I can also hear the tires chirping. And the ESP light doesn't come on. Also the steering wheel goes crazy in my hands.
I'm going to go buy a large torque wrench this weekend. I have 2 torque wrenches already, but they are for my motorcycle repairs, so one is very low (IE: in/lbs) and the other only goes up to 80 ft/lbs- never needed anything larger before now)... Anyway... Newbie question (since I am new to working on anything with 4 wheels)- can someone post a picture of the trackbar & bolt that should be checked?
http://project-jk.com/jeep-jk-write-...-end-alignment
How about an alignment? My old TJ got the death wobble exactly the same times as you, turning on a highway, hitting the little bumps, ect... on a 5 hour drive from CT to MD, needless to say it was hell. I stopped at a tire shop who quoted me >$1000 to fix everything that they felt could cause it. I didn't see a problem with anything they mentioned and chose to take it to a different shop and have an alignment... problem solved, no more death wobble although I still cringed everytime I hit a bump for months afterward.
Yes, alignment and loose track bar account for 90% of death wabbles so I'm told. I picked one up after I bent my tie rod causing my alignment to be toed in. Checked the track bar and had it aligned. All is better now.
