Stock engine rebuild question
Old May 30, 2011 | 06:13 AM
Jeep_in's Avatar
Default Stock engine rebuild question
Do we have someone that has rebuilt their crapped-out factory engine? I am asking because from the failures I see from all the posts, it would be a great idea how to pull and rebuild my engine after it fails (already burning high rate of oil and no lifetime warranty). A lot of us are very mechanical yet do not have the technical knowledge on how to do the job.
This support would be a phenomenal tool for many of us.
Just a thought...
Old May 30, 2011 | 06:41 AM
JKRVEE's Avatar
I've only got 32k on mine, but when it goes, I'm going to rebuild with that $3200 stroker kit for sure!
Old May 30, 2011 | 06:44 AM
B09RUBI's Avatar
What stroker kit? I would like to know
Old May 30, 2011 | 06:48 AM
JKRVEE's Avatar
The company name is Hesco, $3169.00, and it's claim is the same power as the new penstar.
Old May 30, 2011 | 02:42 PM
pirate's Avatar
I would buy a shop manuel and study that. It will explain how to pull the eng and re-install it. As well it will go into details on how to overhaul it. They are not to hard (rebuilt other engs, not the jeeps) to do but they are time consuming to do.
Old May 30, 2011 | 02:50 PM
ronjenx's Avatar
Yup. Don't even consider rebuilding without the proper tech data.
Old May 30, 2011 | 04:26 PM
Jeep_in's Avatar
Default Shop Manual
Would the Shop Manual be written for a layman like me to understand? It is not as much a problem as having the aptitude as much as the professional understanding of the lingo. If I read it thoroughly you think I could get by? By the way, thank you all for the help!!!
Old May 30, 2011 | 05:38 PM
sa29560's Avatar
It is going to have a lot of numbers for all the timing, stroke, and torque values. If this is stuff that is already foreign, it will be pretty tough to pick up on the fly.
There really isn't much more building than measuring really.
A lot of tools are absolutely necessary that may not be considered your everyday ratchets and wrenches.
But as a starting point for it all, hit the literature. As others have said, you have to use it.
For all the time and labor, I would stroke it as well.
Old May 31, 2011 | 04:53 AM
pirate's Avatar
Shop manuals are usually written for the layman, but they do go into some detail that's hard to understand, or they just don't talk about what you really want to know. It's best to buy multiple manuals and use all of them. The older the vehicle the more choices you have. But the best one are the ones the dealer uses but they are the most expensive.
If you want to see if it's clear enough for you go and grab and manual from an a book store and thumb thru it and see if you understand what they are telling you. Just browse don't buy.
Old Jun 4, 2011 | 03:25 AM
Jeep_in's Avatar
Default Absolutely will
Thank you for the support and explanations.
